vaught
#1 Posted : Thursday, April 26, 2012 8:04:50 AM(UTC)
vaught
how to replace oven sensor and where is it located?
Simon / APP Team
#2 Posted : Thursday, April 26, 2012 2:39:18 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The oven sensor could be found in the upper corner inside the oven.
To replace it remove two screws holding it and gently pull it out until you will see the plug or the wire nuts.
Plug in a new one or splice it in.
Reinstall the sensor back.
The oven sensor Part number: 8053344
Here are the breakdown diagrams and Replacement parts for Whirlpool SF385PEEZ0 GAS RANGE | AppliancePartsPros.com
Thank you. Post the results.
Simon.
