how to replace oven sensor and where is it located?
Groups: APP Team
Hi. The oven sensor could be found in the upper corner inside the oven. To replace it remove two screws holding it and gently pull it out until you will see the plug or the wire nuts. Plug in a new one or splice it in. Reinstall the sensor back. The oven sensor Part number: 8053344
