shokwaves
#1 Posted : Monday, October 26, 2009 2:15:46 AM(UTC)
shokwaves
Ok, here it goes. Oven stopped working after self-clean. Oven bake ignitor looked shot, replaced it. Still does not work. Code F14 displayed. Called J-A, they advised it was a runaway lower oven temp - likely the oven sensor or the ribbon board in control pannel.
The control panel is out of warranty, but they will send free if a certified repair tech ($130 to say hi + repair fee) verifies. Sensor is $40 +/-. I will try sensor first unless someone says not to.
How do I replace sensor? I heard the back panel must be removed in order to access it. Does the sensor wire connect to control panel or elsewhere? Are there any fuses (thermal or otherwise) that I check to see if they were blown?
Thanks for your assistance in advance!
Al
#2 Posted : Monday, October 26, 2009 5:09:24 PM(UTC)
Quote:
...it was a runaway lower oven temp...
According to the breakdown diagrams there is only one oven in your range and there is no "F14" error code listed for this model.
I would recommend to perform the troubleshooting as described in the Service manual.
Here are the breakdown diagrams and Replacement parts for JENN-AIR JGR8875QDS | AppliancePartsPros.com
shokwaves
#3 Posted : Monday, October 26, 2009 6:12:02 PM(UTC)
shokwaves
Gene,
Yes, I am aware this range obviously has only 1 oven. As for the code, that's what it is. Per the Jenn-air contact #, that is what they told me "runaway" lower oven temp - which means either the oven sensor or the ribbon control panel.
I am trying to find someone who can walk me through the process of finding where the power lead for the sensor is. This way, I can try to replace it as it is a lot cheaper to try that first.
I also want someone with experience to let me know if this unit has any fuses that might have blown, and to explain where they are.
Thanks.
#4 Posted : Monday, October 26, 2009 6:26:54 PM(UTC)
The are no fuses which can affect oven temperature. You can find all disassemble procedures in the Service manual.
The sensor harness plug is behind the rear range panel.
