silverbullet
#1 Posted : Sunday, September 20, 2009 12:08:25 PM(UTC)
silverbullet
yes, this is a york and i condensor fan runs at 1/2 speed (the HO said that it quit in the middle of the night~. when i got there he had it off for a while and when i turned it on it ran slow and compressor was not runnin originally thought it was a cap. being that it was a 40 uhf +- 5 so i changed that and still the same problem i have current going to the fan a comp.. jus any more info would be goos thanks..
SublimeMasterJW
#2 Posted : Monday, October 5, 2009 3:41:00 PM(UTC)
SublimeMasterJW
If it is running half speed it could be poling out. Move the shaft and check for play in it. If it moves more than a frogs hair it is probably bad. Should have absolutely no lateral play at all. If it feels sloppy the bearing is gone.
silverbullet
#3 Posted : Monday, October 5, 2009 4:51:58 PM(UTC)
silverbullet
yes, actually it was a bad capicator. there were no data plate and someone tried to run a 45 -+ 5 mf for the compressor and fan.
so changed that and put a 5 mf for the fan and it was fixed. dont know how long the fan will rum though since the other person wired it this way.
SublimeMasterJW
#4 Posted : Monday, October 5, 2009 7:26:40 PM(UTC)
SublimeMasterJW
My fan quit on my outside unit not long ago and it was a swollen 5 mike cap.
I think these newer PCB free caps ain't as tough as the old school ones.
Condensor Fan won't turn on, runs when lightly touched (Refrigerator & Freezer Repair)
by iceskaters 4/12/2013 11:08:13 AM(UTC)
GE Profile Refrigerator Condensor fan (Refrigerator & Freezer Repair)
by gdaddy 1/14/2013 7:26:38 AM(UTC)
GE Condensor fan motor (Refrigerator & Freezer Repair)
by 1Keith1 9/6/2012 5:45:32 AM(UTC)
Replaced the condensor fan not working (Refrigerator & Freezer Repair)
by yoitjackie 8/20/2012 1:45:01 PM(UTC)
Whirlpool condensor fan motor - spin direction (Refrigerator & Freezer Repair)
by mikect63 7/3/2012 6:58:21 PM(UTC)
No power to compressor or condensor fan (Refrigerator & Freezer Repair)
by David C. 6/16/2012 10:09:30 PM(UTC)
Condensor Fan Noisy (Refrigerator & Freezer Repair)
by billlaurie7 2/20/2012 2:20:30 PM(UTC)
Admiral Condensor Fan Wiring (Refrigerator & Freezer Repair)
by Larzz87 12/4/2011 12:43:10 PM(UTC)
Condensor Fan Motor? (Refrigerator & Freezer Repair)
by quietmale3269 10/28/2011 8:12:42 AM(UTC)
compressor continuously runs, condensor fan is not running, warm fridge (Refrigerator & Freezer Repair)
by Trudy12357 8/28/2011 1:43:33 PM(UTC)
Condensor fan not running (Refrigerator & Freezer Repair)
by jtrski 7/11/2011 1:15:31 PM(UTC)
Condensor fan runs slowly (Refrigerator & Freezer Repair)
by joeysgrandpa 4/4/2011 12:53:59 PM(UTC)
Anything between mother board and condensor fan? (Refrigerator & Freezer Repair)
by pikeslime 4/2/2011 12:53:41 PM(UTC)
Condensor Fan noise (Refrigerator & Freezer Repair)
by gtl545 2/21/2011 9:03:37 AM(UTC)
Condensor fan not running. power to the 3wire plug has 11.5 vdc on 2 legs. (Refrigerator & Freezer Repair)
by h60mech 10/16/2010 9:59:07 AM(UTC)
