mikect63
#1 Posted : Tuesday, July 3, 2012 6:58:21 PM(UTC)
mikect63
I'm replacing the condensor fan motor on my Whirlpool fridge. (Appliance Parts Part no. AP3120994/Whirlpool part #833697.) Everything I read says that the fan should spin clockwise, but mine is spinning counter-clockwise. I reversed the wires and it still spins counter-clockwise. The compressor and the condensor coils are both in the same direction - should the fan be blowing air onto the compressor and condensor coils? Or is the fan drawing away even if I don't feel it? Thx.
#2 Posted : Wednesday, July 4, 2012 12:47:36 AM(UTC)
All these type motors turn counterclockwise viewed from the back. If you use the old fan blade, it must turn in a direction to cup the air and blow it out with "normal" velocity. If not, either your fan blade is bent the wrong way, or it's the wrong blade.
mikect63
#3 Posted : Wednesday, July 4, 2012 5:07:38 AM(UTC)
mikect63
Thanks very much for the info. Just to be sure I understand:
Right now the air is blowing away from the condensor coils and away from the compressor. Is that correct?
mikect63
#4 Posted : Wednesday, July 4, 2012 5:09:04 AM(UTC)
mikect63
In other words, because of the location and position of the fan, the air is being directed against the sidewall of the refrigerator, it is not directly flowing "out." Thanks again for any insight you can lend.
#5 Posted : Wednesday, July 4, 2012 5:40:41 AM(UTC)
The fan blade must cool the condenser and the compressor, either direction of flow is ok. If the fan blade is not bent and the original one, you are probably ok. A fan blade bent the wrong way will not blow much air.
mikect63
#6 Posted : Wednesday, July 4, 2012 5:48:35 AM(UTC)
mikect63
Great. Thanks very much. Enjoy your 4th of July!
Guest
#7 Posted : Tuesday, April 2, 2024 1:05:27 AM(UTC)
Guest
Rank: Guest
Groups: Guests
United States
Oops let's rethink this
Guest
#8 Posted : Wednesday, June 26, 2024 1:49:52 PM(UTC)
Guest
Rank: Guest
Groups: Guests
United States
My fan is blowing away from the compressor and condenser coils!! Is that ok??
applianceaid1
#9 Posted : Wednesday, June 26, 2024 7:05:23 PM(UTC)
applianceaid1
Canada
Was thanked: 10 time(s) in 10 post(s)
**My fan is blowing away from the compressor and condenser coils!! Is that ok??**
As long as it is drawing in cooler room air and expelling the hot air from the condenser coils and compressor out....is should be ok.
jeff sr.
Appliance Repair Aid
https://www.applianceaid.com/
