dsbowler
#1 Posted : Monday, July 9, 2012 9:19:24 AM(UTC)
dsbowler
I have a Beaumark Dishwasher model 400813. It is only draining a trickle. The discharge pump has become very 'quiet'. | took off the pump screen inside the tub and ran some CLR through it. Appears to have a white gummy film. Tried blowing in the discharge hose where it feeds to the sink. No air movement. I used an air compressor and no air movement. After several attempts with the air hose, I heard a 'pop'. Now air moves freely through the discharge hose; i checked and it is still connected to the discharge pump. Still minimal water and will not pump up if the hose is attached to the sink drain. Only will run down stream into a bucket at low flow (seems like by gravity only, not force of a pump) and water remains in the tub. Any suggestions?
#2 Posted : Wednesday, July 11, 2012 1:30:55 AM(UTC)
I cannot find any info using the given model number,
Is there another model number on the unit?
Model numbers are usually a combination of letters and numbers but BeauMark may be different, I do not know their numbering scheme.
Model Number Locator
I can tell you that most BeauMark's are made by GE.
Ge does make several different pumps so helping without info on the unit is not possible.
dsbowler
#3 Posted : Wednesday, July 11, 2012 6:03:57 AM(UTC)
dsbowler
Unfortunately the model number is what is posted. My Google searching suggested to replace the piston and nut assembly. It was a GE part. Put it in and it's working like brand new again.
washer water not draining (Washer Repair)
by mwashbu 10/21/2019 2:14:42 PM(UTC)
Water not draining (Washer Repair)
by macismom 2/28/2014 2:40:48 PM(UTC)
by kyarbrough5@cox.net 7/15/2012 5:04:08 PM(UTC)
by hillestad 12/29/2011 9:09:22 PM(UTC)
Came home to burnt rubber smell and water not draining from Washer (Washer Repair)
by kota701 12/8/2011 11:27:57 AM(UTC)
Water not Draining (Washer Repair)
by ccino1 10/26/2011 7:38:45 PM(UTC)
Water not draining after new pump was installed (Dishwasher Repair)
by lloyd520 12/29/2010 4:44:42 PM(UTC)
water not draining completely (Dishwasher Repair)
by ronmer 5/5/2010 6:51:43 AM(UTC)
Water not draining (Dishwasher Repair)
by mrmrst 4/21/2009 10:24:22 AM(UTC)
water not draining (Dishwasher Repair)
by image252 2/9/2009 10:48:51 AM(UTC)
Washer water not draining from rinse cycle (Washer Repair)
by Michaele 11/24/2008 3:21:47 AM(UTC)
