I have a Beaumark Dishwasher model 400813. It is only draining a trickle. The discharge pump has become very 'quiet'. | took off the pump screen inside the tub and ran some CLR through it. Appears to have a white gummy film. Tried blowing in the discharge hose where it feeds to the sink. No air movement. I used an air compressor and no air movement. After several attempts with the air hose, I heard a 'pop'. Now air moves freely through the discharge hose; i checked and it is still connected to the discharge pump. Still minimal water and will not pump up if the hose is attached to the sink drain. Only will run down stream into a bucket at low flow (seems like by gravity only, not force of a pump) and water remains in the tub. Any suggestions?
I cannot find any info using the given model number, Is there another model number on the unit? Model numbers are usually a combination of letters and numbers but BeauMark may be different, I do not know their numbering scheme. Model Number LocatorI can tell you that most BeauMark's are made by GE. Ge does make several different pumps so helping without info on the unit is not possible. |
THIS FORUM IS DEAD!!!!!!! |
Unfortunately the model number is what is posted. My Google searching suggested to replace the piston and nut assembly. It was a GE part. Put it in and it's working like brand new again.
