Replacement parts for Whirlpool LER7646EQ1 DRYERS | AppliancePartsPros.comHow did you defeat the switch?
Does the drum light work?
I would start by checking the power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Next would be the thermal fuse (Item 7 in Section 3).
If it is blown, give the interior a good cleaning, including the blower wheel.
Also check/clean your vent system as this is the most common cause of it blowing.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
