I need to replace the dryer door switch assembly. Is this something that I can easily do myself or should I call an appliance repair shop? If doing myself, how best to access the defective part? Thanks in advance.
Originally Posted by: Lewbie  I need to replace the dryer door switch assembly. Is this something that I can easily do myself or should I call an appliance repair shop? If doing myself, how best to access the defective part? Thanks in advance. Lewbie, It's pretty much an easy repair, can be done with basic handtools, and a putty knife(or simmilar flat blade). Is this the part you have ? Part number: AP3132865
To replace the door switch, Turn off the power to the unit or unplug the power cord. Remove the lint filter, remove the two phillips head screws holding the filter housing to the top panel. Using a putty knife, insert the blade in the seam,between the top and front panel, approximately 2 or 3 inches in from the side, and push in, to release the spring retainer clip(s) and raise the top,( you may want to use a rod or move the dryer out a few inches so you can prop the top against the wall). Open the dryer door, you may want to prop it open as well, and remove the two small phillips head screws(each side of the lever) remove the wires from the wire clip, and lift the switch assembly up and out. Reverse the procedure and test unit operation. My guess is, it'll take you 15 to 20 minutes to do the repair. Good Luck, :) :) :)
Thanks. You make it sound so easy. I'll give it a shot.
Originally Posted by: Lewbie  Thanks. You make it sound so easy. I'll give it a shot. Lewbie, You're welcome, I'm pretty sure you'll be fine, you might even have fun at it. Drop us a line when you're done. :) :) :)
Piece of cake, Jim. Took 8 minutes exactly. Thanks for such great instructions. Works fine and saved beaucoup bucks!:)
Sorry--I mean JOE! Thanks a million JOE!!!
Originally Posted by: Lewbie  Sorry--I mean JOE! Thanks a million JOE!!! Lewbie, You did it all, I just gave you a rough idea, Pat yourself on the back, you deserve it. Great job, :) :) :)
