Martin Pollyea
#1 Posted : Sunday, September 9, 2012 9:17:06 AM(UTC)
Martin Pollyea
I ordered a new door switch for my Kenmore Series 80 dryer. The switch came and looks identical to the one it is replacing. It has three wires that slip into a plastic connector with red, blue and white leads. However, I noticed the blue wire coming out of the switch (coded blue with a paint dot) is in the middle of the three, while the blue wire in the plastic female connector is on the outside. So, the red and blue wires are not meeting (connected). Is this an error, or should it work?
The original problem is that the dryer would not start. So, I replaced the push-start button. That did not solve the problem. So now I am trying the door switch. The old one is definitely bad. Which brings me to my question, above, about the door switch wires.
Thank You for reading/responding to this. I cannot afford another $600 for a new dryer.
#2 Posted : Monday, September 10, 2012 2:59:53 AM(UTC)
Need a model number so I can try and find a wiring diagram for this unit.
Model Number Locator
intermittant dryer door switch (Dryer Repair)
by Jstanh 12/22/2013 4:43:59 PM(UTC)
GE stack Dryer door switch (Dryer Repair)
by abigail17 11/14/2012 8:30:25 AM(UTC)
Dryer Door Switch (Dryer Repair)
by jtnewton 7/8/2012 7:44:31 AM(UTC)
Replace dryer door switch (Dryer Repair)
by adenise 12/7/2011 10:45:57 AM(UTC)
dryer door switch replacement (Dryer Repair)
by noto 6/1/2011 6:42:10 AM(UTC)
Dryer door switch replacement (Dryer Repair)
by BK1 4/24/2011 12:09:17 PM(UTC)
Maytag dryer door switch wiring (Dryer Repair)
by LynnVan 4/18/2011 4:32:12 AM(UTC)
Replacing Kenmore Dryer Door Switch (Dryer Repair)
by JCR12 3/19/2011 7:32:47 AM(UTC)
Dryer door switch assembly (Dryer Repair)
by Lewbie 1/21/2011 7:16:57 AM(UTC)
Remove and replace dryer door switch (Dryer Repair)
by billbrower 10/30/2010 12:13:00 PM(UTC)
by megma 3/22/2010 5:29:40 PM(UTC)
Dryer door switch piece fell off (Dryer Repair)
by brokenasusual 2/10/2010 9:59:38 AM(UTC)
dryer door switch 3 to 2 wire (Dryer Repair)
by brian291 6/22/2009 6:48:47 AM(UTC)
How do I replace a Kenmore Stackable Dryer Door Switch? (Dryer Repair)
by username6454 5/14/2009 1:59:59 PM(UTC)
whirlpool dryer door switch (Dryer Repair)
by rcubed1 12/11/2008 1:16:46 PM(UTC)
