How do I replace the dryer door switch?
Groups: APP Team
Hi.
Please provide the complete model number of the unit.
Simon.
Simon. WSM2420 is the number I copied. Serial# isSH6006222. Hope this helps. Thanks.
Originally Posted by: abigail17  WSM2420 is the number I copied. Serial# isSH6006222. Hope this helps. Thanks. There is more to the model number There are several models which begin WSM2420. Here is one example: WSM2420D0CC Other models have four or more letters and / or numbers following. Double check the model number on the serial number plate.
Originally Posted by: TommyK  There is more to the model number There are several models which begin WSM2420. Here is one example: WSM2420D0CC Other models have four or more letters and / or numbers following.
Double check the model number on the serial number plate. The unit is in Florida and I am in Ohio. I will be down thre next month and will get back to you then. Thanks very much.
The Model # is WSM2-42OD 1WW. Hope this helps.
Groups: APP Team
