hi my oven goes on but on its own turns off. spesifically when i bake a second time in the same day it just wont stay on. I think it is the thermostat. what do you say?
Most likely the problem is a bad thermostat but I would recommend to replace the pilot assembly at the same time because there is definitely a lot of build-ups inside. It will make the repair more reliable. - The thermostat Part number: WB20K10013
