mlevy770
#1 Posted : Tuesday, June 19, 2012 8:26:04 PM(UTC)
mlevy770
hi my oven goes on but on its own turns off.
spesifically when i bake a second time in the same day it just wont stay on.
I think it is the thermostat. what do you say?
#2 Posted : Wednesday, June 20, 2012 2:40:03 PM(UTC)
Most likely the problem is a bad thermostat but I would recommend to replace the pilot assembly at the same time because there is definitely a lot of build-ups inside. It will make the repair more reliable.
- The thermostat Part number: WB20K10013
Gas smell after oven turns off (Oven Repair (including Ranges and Cooktops))
by Mtfalk64 2/17/2022 2:16:10 AM(UTC)
Oven turns off after it heats up (Oven Repair (including Ranges and Cooktops))
by Guest 4/10/2021 9:05:44 AM(UTC)
Thermador Double Oven - Top Oven turns off F5 and F7 (Oven Repair (including Ranges and Cooktops))
by MattLester 2/9/2015 12:11:39 PM(UTC)
GE Monogram double oven turns off when temperature changed (Oven Repair (including Ranges and Cooktops))
by mlovelace 12/25/2014 9:26:27 AM(UTC)
Thermador oven turns off when baking/broiling (Oven Repair (including Ranges and Cooktops))
by nolanfr12 8/24/2011 6:06:46 PM(UTC)
Oven turns off (Oven Repair (including Ranges and Cooktops))
by efudd 9/22/2010 3:22:25 PM(UTC)
Oven turns off, then resets in middle of cooking (Oven Repair (including Ranges and Cooktops))
by bdsammon 9/10/2010 5:42:47 AM(UTC)
by mtalbo 1/14/2010 9:42:09 AM(UTC)
Gas oven turns off -no error code -part help needed (Oven Repair (including Ranges and Cooktops))
by barbboy 9/18/2009 4:32:03 PM(UTC)
Range/Oven turns off (Oven Repair (including Ranges and Cooktops))
by bknelms 7/12/2009 10:28:11 AM(UTC)
Whirlpool Double Oven Turns Off Before Heating (Oven Repair (including Ranges and Cooktops))
by BlazeMiller 6/19/2009 2:10:10 PM(UTC)
F9 code Oven turns off,lock light turns on,door does not lock (Oven Repair (including Ranges and Cooktops))
by darling132 11/12/2008 11:53:40 AM(UTC)
amana elec wall oven turns off (Oven Repair (including Ranges and Cooktops))
by amana98 8/27/2008 6:45:05 AM(UTC)
GE Profile Convention Oven Turns Off When Preheating (Oven Repair (including Ranges and Cooktops))
by martys 1/22/2008 2:56:57 PM(UTC)
