mtalbo
#1 Posted : Thursday, January 14, 2010 9:42:09 AM(UTC)
mtalbo
My Maytag Performance oven turns off after about 3 minutes of heating up. The stove top works well. This morning my wife stated she smelled gas in the kitchen. The gas line is now turned off. Matt
#2 Posted : Thursday, January 14, 2010 12:33:52 PM(UTC)
What is the complete model number of the range?
What does the display show when it turns off?
mtalbo
#3 Posted : Thursday, January 14, 2010 7:54:00 PM(UTC)
mtalbo
Maytag Performa Model PGR5710BDW.
The oven turns on and heats up. The oven temp shows 400 then after 3-4 minutes the oven turns off, then after 30 seconds the panel will show the time blinking. We can turn the oven back on but it will continue to turn off. Thanks Matt
#4 Posted : Friday, January 15, 2010 11:25:24 AM(UTC)
Hi Matt,
Sounds like the problem is a bad control board.
- The control board Part number: AP4396588
Gas smell after oven turns off (Oven Repair (including Ranges and Cooktops))
by Mtfalk64 2/17/2022 2:16:10 AM(UTC)
Oven turns off after it heats up (Oven Repair (including Ranges and Cooktops))
by Guest 4/10/2021 9:05:44 AM(UTC)
Thermador Double Oven - Top Oven turns off F5 and F7 (Oven Repair (including Ranges and Cooktops))
by MattLester 2/9/2015 12:11:39 PM(UTC)
GE Monogram double oven turns off when temperature changed (Oven Repair (including Ranges and Cooktops))
by mlovelace 12/25/2014 9:26:27 AM(UTC)
by mlevy770 6/19/2012 8:26:04 PM(UTC)
Thermador oven turns off when baking/broiling (Oven Repair (including Ranges and Cooktops))
by nolanfr12 8/24/2011 6:06:46 PM(UTC)
Oven turns off (Oven Repair (including Ranges and Cooktops))
by efudd 9/22/2010 3:22:25 PM(UTC)
Oven turns off, then resets in middle of cooking (Oven Repair (including Ranges and Cooktops))
by bdsammon 9/10/2010 5:42:47 AM(UTC)
Gas oven turns off -no error code -part help needed (Oven Repair (including Ranges and Cooktops))
by barbboy 9/18/2009 4:32:03 PM(UTC)
Range/Oven turns off (Oven Repair (including Ranges and Cooktops))
by bknelms 7/12/2009 10:28:11 AM(UTC)
Whirlpool Double Oven Turns Off Before Heating (Oven Repair (including Ranges and Cooktops))
by BlazeMiller 6/19/2009 2:10:10 PM(UTC)
F9 code Oven turns off,lock light turns on,door does not lock (Oven Repair (including Ranges and Cooktops))
by darling132 11/12/2008 11:53:40 AM(UTC)
amana elec wall oven turns off (Oven Repair (including Ranges and Cooktops))
by amana98 8/27/2008 6:45:05 AM(UTC)
GE Profile Convention Oven Turns Off When Preheating (Oven Repair (including Ranges and Cooktops))
by martys 1/22/2008 2:56:57 PM(UTC)
