I am trying to replace the door latch and the old door latch connectors will not release from the electrical cords? Is there an easy way to pull the connectors from the wires?
Not sure what you are referring to. If you mean getting the connectors off the door latch switches often a flat screw driver of the correct size will do it. Put the driver blade between the switch body and the connector and then twist the screwdriver forcing the connector back off the switch. You may have to work from side to side till it backs off enough. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Not sure what you are referring to. If you mean getting the connectors off the door latch switches often a flat screw driver of the correct size will do it. Put the driver blade between the switch body and the connector and then twist the screwdriver forcing the connector back off the switch. You may have to work from side to side till it backs off enough. Thank you! We got it.:D
