Kapraunfarms
#1 Posted : Tuesday, June 19, 2012 10:09:55 AM(UTC)
Kapraunfarms
I am trying to replace the door latch and the old door latch connectors will not release from the electrical cords? Is there an easy way to pull the connectors from the wires?
#2 Posted : Tuesday, June 19, 2012 10:37:57 AM(UTC)
Not sure what you are referring to.
If you mean getting the connectors off the door latch switches often a flat screw driver of the correct size will do it.
Put the driver blade between the switch body and the connector and then twist the screwdriver forcing the connector back off the switch.
You may have to work from side to side till it backs off enough.
Kapraunfarms
#3 Posted : Tuesday, June 19, 2012 11:40:42 AM(UTC)
Kapraunfarms
Thank you! We got it.:D
Maytag dishwasher model MDB4949SKZ1 (Dishwasher Repair)
by thepontif 2/3/2024 11:15:46 AM(UTC)
Maytag dishwasher drain always runs? (Dishwasher Repair)
by Guest 12/15/2023 6:04:35 PM(UTC)
Heating element won't turn off on Maytag dishwasher (Dishwasher Repair)
by Guest 8/2/2023 6:10:10 AM(UTC)
Maytag dishwasher not cleaning top shelf very well. (Dishwasher Repair)
by Guest 10/20/2022 10:23:08 AM(UTC)
Maytag dishwasher leak from bottom of door (Dishwasher Repair)
by Guest 7/27/2022 1:58:00 PM(UTC)
Maytag dishwasher, cancel button (Dishwasher Repair)
by jtt21 6/28/2022 5:24:58 PM(UTC)
Maytag dishwasher quiet series 300 (Dishwasher Repair)
by Guest 6/12/2022 7:04:36 PM(UTC)
Maytag Dishwasher Not Entering Installation Cycle (Dishwasher Repair)
by Sparky9680 5/16/2022 9:37:56 AM(UTC)
Maytag dishwasher MDB4709AWW1 (Dishwasher Repair)
by dkmc1953 3/6/2022 1:13:12 PM(UTC)
Maytag Dishwasher stops several times during normal cycle (Dishwasher Repair)
by vanordens3 12/28/2021 12:26:19 PM(UTC)
Maytag Dishwasher Making Clanging Noise Even When Empty (Dishwasher Repair)
by gtg931 12/20/2021 7:13:20 PM(UTC)
Maytag dishwasher leaking and smoking (Dishwasher Repair)
by Guest 10/19/2021 2:58:51 PM(UTC)
Maytag dishwasher MDB4949SDZ0 (Dishwasher Repair)
by tonygm 5/29/2021 1:47:18 PM(UTC)
Maytag Dishwasher LEAKING underneath (Dishwasher Repair)
by bakerid2000 9/5/2019 5:49:20 PM(UTC)
Maytag dishwasher fills, then drains (Dishwasher Repair)
by vtfireman85 3/12/2019 7:30:34 PM(UTC)
