Cindi Cescon
#1 Posted : Monday, June 11, 2012 11:50:52 AM(UTC)
Cindi Cescon
This refridgerator is a side by side. When you open the two doors, the diverder that divides the freezer and the fridge is super hot. What could cause this?
Cindi Cescon
#2 Posted : Monday, June 11, 2012 11:52:50 AM(UTC)
Cindi Cescon
Originally Posted by: Cindi Cescon Go to Quoted Post
This refridgerator is a side by side. When you open the two doors, the diverder that divides the freezer and the fridge is super hot. What could cause this? I have vacummed out the fridge's coils as well as was suggested but this did not help:mad: ]
Cindi Cescon
#3 Posted : Monday, June 11, 2012 11:55:03 AM(UTC)
Cindi Cescon
This refridgerator is a side by side. When you open the two doors, the diverder that divides the freezer and the fridge is super hot. What could cause this? I have vacummed out the fridge's coils as well as was suggested but this did not help:mad: Any suggestions on what to do to eliminate this fridge from breaking down
#4 Posted : Monday, June 11, 2012 3:43:16 PM(UTC)
Didi you also check/clean the vents in the rear cover, the vents in the kick/plate (front) and the condenser/compressor fan blade?
Also check that the condenser/compressor fan runs when the compressor is on.
Note: It will take at least a few hours to notice if the frame cools down.
I cannot find any info on the given model number, please check it.
If it is a non USA unit I may not be able to get info on it.
Viking Refridgerator temp control issue (Refrigerator & Freezer Repair)
by nmunn 8/23/2018 4:04:33 PM(UTC)
KitchenAid refridgerator fans run continusly & click off and on (Refrigerator & Freezer Repair)
by neutron68 7/29/2018 3:24:56 PM(UTC)
Refridgerator with confusing symptoms (Refrigerator & Freezer Repair)
by jingee007 8/25/2017 2:42:13 PM(UTC)
Refridgerator/Freezer not cooling enough (Refrigerator & Freezer Repair)
by blbrchnk 12/15/2016 5:08:53 AM(UTC)
Kenmore Elite refridgerator control panel dead (Refrigerator & Freezer Repair)
by MarshalW 9/2/2016 5:07:59 AM(UTC)
Maytag Refridgerator Cool, Freezer is cool but not freezing, compressor very hot (Refrigerator & Freezer Repair)
by luck11 4/23/2016 4:28:11 AM(UTC)
GE Refridgerator frost/ice buildup in freezer. (Refrigerator & Freezer Repair)
by sask3m 2/5/2016 12:22:13 PM(UTC)
Samsung Refridgerator display frozen and moves on its own (Refrigerator & Freezer Repair)
by mesaheat 8/17/2015 1:27:26 PM(UTC)
GE Refridgerator is not freezing or cooling. (Refrigerator & Freezer Repair)
by ChestyPuller 8/16/2015 10:20:43 AM(UTC)
Amana Refridgerator - Gasket causing too warm temps? (Refrigerator & Freezer Repair)
by RichardBrum 8/12/2015 5:42:40 AM(UTC)
MAYTAG refridgerator compressor runs for 10 seconds (Refrigerator & Freezer Repair)
by scubastevexj 6/25/2015 4:48:53 PM(UTC)
samsung side by side refridgerator (Refrigerator & Freezer Repair)
by jeeper333rc 4/26/2015 6:43:20 AM(UTC)
Refridgerator getting too cold (Refrigerator & Freezer Repair)
by Regulator23 3/9/2015 8:54:15 AM(UTC)
refridgerator not coming on when it should (Refrigerator & Freezer Repair)
by howiedude 11/30/2014 7:27:23 PM(UTC)
Whirlpool refridgerator is cold but does not freeze (Refrigerator & Freezer Repair)
by minhly82 11/4/2014 7:49:33 PM(UTC)
