This refridgerator is a side by side. When you open the two doors, the diverder that divides the freezer and the fridge is super hot. What could cause this?
Originally Posted by: Cindi Cescon This refridgerator is a side by side. When you open the two doors, the diverder that divides the freezer and the fridge is super hot. What could cause this? I have vacummed out the fridge's coils as well as was suggested but this did not help:mad: ]
Originally Posted by: Cindi Cescon Originally Posted by: Cindi Cescon This refridgerator is a side by side. When you open the two doors, the diverder that divides the freezer and the fridge is super hot. What could cause this? I have vacummed out the fridge's coils as well as was suggested but this did not help:mad: Any suggestions on what to do to eliminate this fridge from breaking down
Didi you also check/clean the vents in the rear cover, the vents in the kick/plate (front) and the condenser/compressor fan blade?
Also check that the condenser/compressor fan runs when the compressor is on.
Note: It will take at least a few hours to notice if the frame cools down.
I cannot find any info on the given model number, please check it. If it is a non USA unit I may not be able to get info on it. |
THIS FORUM IS DEAD!!!!!!! |
