There is a large puddle in the floor under and around the washer. I have replaced the engine to trans coupling a few years back and it's been ok ever since. I got the clothes out, and turned it on small load, let it fill up with water, and it is agitating, and going thru cycles, and it SOUNDS like there is some water going out the drain, but there is still some in the floor. Any help is appreciated.
Groups: Expert
Originally Posted by: lego126  There is a large puddle in the floor under and around the washer. I have replaced the engine to trans coupling a few years back and it's been ok ever since. I got the clothes out, and turned it on small load, let it fill up with water, and it is agitating, and going thru cycles, and it SOUNDS like there is some water going out the drain, but there is still some in the floor. Any help is appreciated. If the water seems to be coming from right in front and in the middle, its most likely the water pump seal. If you have changed the coupling, this is even easier. You just need part no. AP2907492
Yes, the water is coming from right in front, and seems to be coming from the pump. I haven't taken it off yet so I can't tell exactly where it's from but, just by tilting it back, it seem sto be coming from the from middle of the pump like it is perhaps cracked of something.. I'll let you know the results tomorrow, when I take it off. And thanks again for the info.
