lego126
#1 Posted : Friday, May 11, 2012 7:45:28 PM(UTC)
lego126
There is a large puddle in the floor under and around the washer. I have replaced the engine to trans coupling a few years back and it's been ok ever since. I got the clothes out, and turned it on small load, let it fill up with water, and it is agitating, and going thru cycles, and it SOUNDS like there is some water going out the drain, but there is still some in the floor. Any help is appreciated.
ThatGuy
#2 Posted : Saturday, May 12, 2012 9:52:14 AM(UTC)
ThatGuy
Groups: Expert
United States
If the water seems to be coming from right in front and in the middle, its most likely the water pump seal. If you have changed the coupling, this is even easier. You just need part no. AP2907492
lego126
#3 Posted : Sunday, May 13, 2012 6:56:42 PM(UTC)
lego126
Yes, the water is coming from right in front, and seems to be coming from the pump. I haven't taken it off yet so I can't tell exactly where it's from but, just by tilting it back, it seem sto be coming from the from middle of the pump like it is perhaps cracked of something.. I'll let you know the results tomorrow, when I take it off. And thanks again for the info.
Kenmore 90 series washer spin problem (Washer Repair)
by NikoletteFancy 3/26/2015 5:51:18 AM(UTC)
kenmore 90 series washer parts (Washer Repair)
by rogerf1970 12/17/2014 7:43:40 AM(UTC)
Kenmore 90 Series Washer Fills then stops (Washer Repair)
by Mike Rekker 3/10/2014 4:32:07 AM(UTC)
Kenmore 90 series washer won't agitate or spin (Washer Repair)
by JayDigger 1/31/2014 9:30:29 AM(UTC)
Kenmore 90 Series washer buzz - dead (Washer Repair)
by ColdHands 1/26/2014 8:33:02 AM(UTC)
Kenmore 90 Series washer will agitate but won't spin (Washer Repair)
by Cowgirl4ever81 4/2/2013 8:24:55 AM(UTC)
by purplesunv 11/10/2011 12:26:56 PM(UTC)
Kenmore 90 series washer won't agitate nor spin (Washer Repair)
by dlynn25 7/17/2011 11:55:34 AM(UTC)
Kenmore 90 Series Washer Jumps when stopped (Washer Repair)
by 2358schwab 6/7/2011 7:41:56 AM(UTC)
Kenmore 90 Series Washer (Washer Repair)
by TheGreenMachine79 12/5/2010 1:24:08 PM(UTC)
kenmore 90 series washer agitates fine barely spins (Washer Repair)
by vbnitro2010 8/10/2010 8:56:32 PM(UTC)
Kenmore 90 series washer slams to a stop after spin cycle (Washer Repair)
by bobbycat71 7/18/2010 5:13:30 AM(UTC)
Kenmore 90 series washer will agitate but not spin or drain (Washer Repair)
by kmyres76 6/15/2010 1:35:05 PM(UTC)
Kenmore 90 series washer (Washer Repair)
by momof4 3/10/2010 5:20:37 PM(UTC)
by Mr Lee 1/16/2010 2:55:31 PM(UTC)
