My electric dryer is not heating. Is it just the Heating Element needed?
The first thing I would do is check if there is 240 VAC at the dryer wall outlet. If there is no proper voltage then check the circuit breakers for the dryer. If there is nothing wrong then check for continuity the heating coils and the high limit thermostat (#3 on the diagram). - The high limit thermostat Part number: AP4036890
