Bobby Tanner
#1 Posted : Sunday, March 18, 2012 7:59:36 AM(UTC)
Bobby Tanner
Gets voltage to run capacitor. capacitor shows no continuity with tester. compressor & fan will not operate.
#2 Posted : Monday, March 19, 2012 5:01:53 AM(UTC)
Replacement parts for Kenmore 3639762811 | AppliancePartsPros.com
If you go to the Sears parts site they do have parts breakdowns, too bad they do like to share them.
Try jiggling the temperature back and forth a bit, if it fires up replace the thermostat.
You said the compressor and the condenser/compressor fan is off but is the evaporator/freezer fan also if. If it is then it may stuck in a defrost cycle.
Looks like the defrost timer is in the control console. There is usually a hole that will let you turn the timer cam with a screw driver without having to take things apart.
Turn the cam if it fires up replace the timer.
Part number: AP2061721
The3 cam is on the back side of the timer in the center or the round area.
Sourcing Run Capacitor -- Viking Wine Cellar (Refrigerator & Freezer Repair)
by lothian.mcadam 7/15/2019 8:23:46 AM(UTC)
New Starting Device with Run Capacitor (Refrigerator & Freezer Repair)
by d13peters 9/13/2016 6:36:21 AM(UTC)
Whirlpool Washer Run Capacitor Melted (Washer Repair)
by Croaker 7/16/2014 4:11:12 PM(UTC)
Refrigerator start relay and run capacitor (Refrigerator & Freezer Repair)
by Old school 1/7/2014 1:49:38 PM(UTC)
Run Capacitor Connections (Refrigerator & Freezer Repair)
by Repair myself 9/12/2013 1:17:08 PM(UTC)
Possible Run Capacitor problem?? (Refrigerator & Freezer Repair)
by JCollins316 5/12/2013 6:34:19 AM(UTC)
Run Capacitor Clicking (Refrigerator & Freezer Repair)
by jrunkle 2/21/2013 5:15:30 AM(UTC)
by bfgoodmudder 12/18/2012 8:00:30 PM(UTC)
R/R Overload relay/run capacitor (Refrigerator & Freezer Repair)
by rusticradio 5/10/2012 5:39:53 AM(UTC)
by Bobby Tanner 3/18/2012 8:07:17 AM(UTC)
how do you test run capacitor/starter-PTC (Refrigerator & Freezer Repair)
by bobmc53 3/10/2011 2:24:43 PM(UTC)
Symptoms of a bad run capacitor? (Refrigerator & Freezer Repair)
by hdivr 3/7/2011 4:19:59 PM(UTC)
Whirpool overload/start device, run capacitor (Refrigerator & Freezer Repair)
by Paulus 3/4/2011 11:27:02 AM(UTC)
What to buy, Thermostat, Relay, Run Capacitor? (Refrigerator & Freezer Repair)
by foxchase 11/19/2010 11:58:24 AM(UTC)
Relay Overload/Run Capacitor (Refrigerator & Freezer Repair)
by ECS 8/12/2010 10:26:59 AM(UTC)
