This is a side by side. My refrigerator top section is warm 50deg but the bottom section of frig is working. Also, the freezer is fine. Where do I start?:confused:
Did you see any frost on the back panel in the freezer?
Gene, Yes there is frost in the back of the freezer. Today it is completely warm in the frig. Brad
Gene, Finally getting back to you. The problem I discovered was no continuity across the defrost heater. Defrost timer and thermostat are fine. I will order the defrost heater, install and get back to you with the results. thanks for your help! Brad
