IAMBrad
#1 Posted : Thursday, January 10, 2008 11:29:54 AM(UTC)
IAMBrad
This is a side by side. My refrigerator top section is warm 50deg but the bottom section of frig is working. Also, the freezer is fine. Where do I start?:confused:
#2 Posted : Thursday, January 10, 2008 5:59:11 PM(UTC)
Did you see any frost on the back panel in the freezer?
IAMBrad
#3 Posted : Friday, January 11, 2008 6:15:06 AM(UTC)
IAMBrad
Gene, Yes there is frost in the back of the freezer. Today it is completely warm in the frig. Brad
#4 Posted : Friday, January 11, 2008 10:15:12 AM(UTC)
Hi Brad,
The problem with your fridge is a faulty defrost system.
You can find the diagnosis instructions in one of my previous posts: http://forum.appliancepartspros...frigerator-too-warm.html
- The part number for the defrost timer (#23 on the controls break down diagram) is AP2111929
- The part number for the defrost thermostat (#21 on the system break down diagram) is AP2150024
- The part number for the defrost heater (#14 on the system break down diagram) is AP2114071
Good luck.
IAMBrad
#5 Posted : Thursday, January 17, 2008 8:00:18 AM(UTC)
IAMBrad
Gene, Finally getting back to you. The problem I discovered was no continuity across the defrost heater. Defrost timer and thermostat are fine. I will order the defrost heater, install and get back to you with the results. thanks for your help! Brad
Kenmore refrigerator/freezer issue (Refrigerator & Freezer Repair)
by rgbradley58 1/30/2024 6:32:20 AM(UTC)
Kenmore Refrigerator Model 111.72695911 Inverter Board (Refrigerator & Freezer Repair)
by jppreble 11/2/2023 2:34:22 PM(UTC)
Kenmore refrigerator model#106.59592992 (Refrigerator & Freezer Repair)
by Guest 5/16/2023 12:53:20 PM(UTC)
795.71073.013 Kenmore Refrigerator - Water leaking in the bottom freezer (Refrigerator & Freezer Repair)
by shreshtluthra 3/16/2023 10:21:43 AM(UTC)
Kenmore Refrigerator trips GFCI (Refrigerator & Freezer Repair)
by A_A_Ron 7/1/2022 11:38:52 AM(UTC)
Kenmore refrigerator breathing (Refrigerator & Freezer Repair)
by Guest 1/3/2022 3:24:07 AM(UTC)
Reading codes from Kenmore Refrigerator (Refrigerator & Freezer Repair)
by caribconsult 11/29/2021 3:18:54 PM(UTC)
Kenmore refrigerator 'ER - dH' code (Refrigerator & Freezer Repair)
by Kanehs 9/22/2020 9:47:19 PM(UTC)
Kenmore Refrigerator Ice Crusher (Refrigerator & Freezer Repair)
by JOSHSKORN 4/27/2020 11:48:08 AM(UTC)
Kenmore refrigerator 3 beeps (Refrigerator & Freezer Repair)
by bluefitness 3/3/2019 5:37:06 AM(UTC)
Kenmore refrigerator: 106.64252402 (Refrigerator & Freezer Repair)
by SGH 1/1/2019 12:39:12 PM(UTC)
Kenmore Refrigerator Pooling Water on Floor (Refrigerator & Freezer Repair)
by vintess 2/17/2017 5:18:47 PM(UTC)
Kenmore Refrigerator not cooling (Refrigerator & Freezer Repair)
by Doug615 5/14/2016 12:27:12 PM(UTC)
Kenmore refrigerator not dispensing water into ice tray (Refrigerator & Freezer Repair)
by Jmfreddy17 1/6/2016 3:10:02 PM(UTC)
Filler tube for Kenmore refrigerator (Refrigerator & Freezer Repair)
by kidcapri73 6/24/2015 2:41:34 PM(UTC)
