IAMBrad
#1 Posted : 17 years ago
IAMBrad
This is a side by side. My refrigerator top section is warm 50deg but the bottom section of frig is working. Also, the freezer is fine. Where do I start?:confused:
#2 Posted : 17 years ago
Did you see any frost on the back panel in the freezer?
IAMBrad
#3 Posted : 17 years ago
IAMBrad
Gene, Yes there is frost in the back of the freezer. Today it is completely warm in the frig. Brad
#4 Posted : 17 years ago
Hi Brad,
The problem with your fridge is a faulty defrost system.
You can find the diagnosis instructions in one of my previous posts: http://forum.appliancepartspros...frigerator-too-warm.html
- The part number for the defrost timer (#23 on the controls break down diagram) is AP2111929
- The part number for the defrost thermostat (#21 on the system break down diagram) is AP2150024
- The part number for the defrost heater (#14 on the system break down diagram) is AP2114071
Good luck.
IAMBrad
#5 Posted : 17 years ago
IAMBrad
Gene, Finally getting back to you. The problem I discovered was no continuity across the defrost heater. Defrost timer and thermostat are fine. I will order the defrost heater, install and get back to you with the results. thanks for your help! Brad
Kenmore refrigerator/freezer issue (Refrigerator & Freezer Repair)
by rgbradley58 about a year ago
Kenmore Refrigerator Model 111.72695911 Inverter Board (Refrigerator & Freezer Repair)
by jppreble about a year ago
Kenmore refrigerator model#106.59592992 (Refrigerator & Freezer Repair)
by Guest 2 years ago
795.71073.013 Kenmore Refrigerator - Water leaking in the bottom freezer (Refrigerator & Freezer Repair)
by shreshtluthra 2 years ago
Kenmore Refrigerator trips GFCI (Refrigerator & Freezer Repair)
by A_A_Ron 3 years ago
Kenmore refrigerator breathing (Refrigerator & Freezer Repair)
by Guest 3 years ago
Reading codes from Kenmore Refrigerator (Refrigerator & Freezer Repair)
by caribconsult 3 years ago
Kenmore refrigerator 'ER - dH' code (Refrigerator & Freezer Repair)
by Kanehs 4 years ago
Kenmore Refrigerator Ice Crusher (Refrigerator & Freezer Repair)
by JOSHSKORN 5 years ago
Kenmore refrigerator 3 beeps (Refrigerator & Freezer Repair)
by bluefitness 6 years ago
Kenmore refrigerator: 106.64252402 (Refrigerator & Freezer Repair)
by SGH 6 years ago
Kenmore Refrigerator Pooling Water on Floor (Refrigerator & Freezer Repair)
by vintess 8 years ago
Kenmore Refrigerator not cooling (Refrigerator & Freezer Repair)
by Doug615 9 years ago
Kenmore refrigerator not dispensing water into ice tray (Refrigerator & Freezer Repair)
by Jmfreddy17 9 years ago
Filler tube for Kenmore refrigerator (Refrigerator & Freezer Repair)
by kidcapri73 10 years ago
