crappieman
#1 Posted : 16 years ago
crappieman
i am geting water from under the washer could it be a hole in the tub
applianceman
#2 Posted : 16 years ago
applianceman
Recheck your model number and post this under washer repair and we will help you.
crappieman
#3 Posted : 16 years ago
crappieman
model number-wa5669malwh
applianceman
#4 Posted : 16 years ago
applianceman
On this model there is a possibility the tub has a hole in it and if it does it is time for a new one. But you need to remove the back and attempt to see where the water is coming from. The water pump will often leak and also there is a rubber boot at the bottom of the tub that will sometimes leak. Post what you find. Clothes Washer Repair Guide
GE Washer Help (Washer Repair)
by enigma 12 years ago
GE washer Help (Washer Repair)
by unhappy 13 years ago
Ge washer help PLEASE (Washer Repair)
by russ1973 15 years ago
Ge Washer Help (Washer Repair)
by crappieman 16 years ago
GE Washer Help Needed (Washer Repair)
by mrhogiyogi 17 years ago
