i am geting water from under the washer could it be a hole in the tub
Recheck your model number and post this under washer repair and we will help you.
Originally Posted by: applianceman  Recheck your model number and post this under washer repair and we will help you. model number-wa5669malwh
On this model there is a possibility the tub has a hole in it and if it does it is time for a new one. But you need to remove the back and attempt to see where the water is coming from. The water pump will often leak and also there is a rubber boot at the bottom of the tub that will sometimes leak. Post what you find. Clothes Washer Repair Guide
