crappieman
#1 Posted : Saturday, August 8, 2009 7:01:54 PM(UTC)
crappieman
i
correction model no wwa5669mal -I am getting water on flood under washer could it be a hole in the tub
laserdog
#2 Posted : Saturday, August 8, 2009 9:20:20 PM(UTC)
laserdog
crappieman
#3 Posted : Saturday, August 8, 2009 10:16:00 PM(UTC)
crappieman
thanks for your help LASERDOG
applianceman
#4 Posted : Sunday, August 9, 2009 9:29:46 AM(UTC)
applianceman
On this model there is a possibility the tub has a hole in it and if it does it is time for a new one. But you need to remove the back and attempt to see where the water is coming from. The water pump will often leak and also there is a rubber boot at the bottom of the tub that will sometimes leak. Post what you find. Clothes Washer Repair Guide
crappieman
#5 Posted : Sunday, August 9, 2009 7:03:03 PM(UTC)
crappieman
there was a hole at the top of the tub about a inch wide and when it spin out the water came out on the floor so i took some clear all purpose silicone sealant and duck tape i put a piece of tape on the outside of the tub over the hole i then put the silicone on the inside of the tub over hole and spade it over the hole and let dry and it work
GE Washer Help (Washer Repair)
by enigma 2/1/2013 11:47:33 AM(UTC)
GE washer Help (Washer Repair)
by unhappy 2/10/2012 7:32:40 PM(UTC)
Ge washer help PLEASE (Washer Repair)
by russ1973 12/3/2009 4:52:46 PM(UTC)
Ge Washer Help (Refrigerator & Freezer Repair)
by crappieman 8/8/2009 5:57:31 PM(UTC)
GE Washer Help Needed (Washer Repair)
by mrhogiyogi 12/11/2007 8:55:36 PM(UTC)
