crappieman
#1 Posted : Saturday, August 8, 2009 5:57:31 PM(UTC)
crappieman
i am geting water from under the washer could it be a hole in the tub
applianceman
#2 Posted : Saturday, August 8, 2009 6:01:21 PM(UTC)
applianceman
Recheck your model number and post this under washer repair and we will help you.
crappieman
#3 Posted : Saturday, August 8, 2009 7:20:18 PM(UTC)
crappieman
model number-wa5669malwh
applianceman
#4 Posted : Sunday, August 9, 2009 9:27:46 AM(UTC)
applianceman
On this model there is a possibility the tub has a hole in it and if it does it is time for a new one. But you need to remove the back and attempt to see where the water is coming from. The water pump will often leak and also there is a rubber boot at the bottom of the tub that will sometimes leak. Post what you find. Clothes Washer Repair Guide
GE Washer Help (Washer Repair)
by enigma 2/1/2013 11:47:33 AM(UTC)
GE washer Help (Washer Repair)
by unhappy 2/10/2012 7:32:40 PM(UTC)
Ge washer help PLEASE (Washer Repair)
by russ1973 12/3/2009 4:52:46 PM(UTC)
Ge Washer Help (Washer Repair)
by crappieman 8/8/2009 7:01:54 PM(UTC)
GE Washer Help Needed (Washer Repair)
by mrhogiyogi 12/11/2007 8:55:36 PM(UTC)
