The door on this dishwasher opens to far. Once open the door is past level with the floor. This creates a bump when rolling the bottom try in or out. Even when open this wide it does not feel solid. Is there a stop somewhere that I'm missing.
Originally Posted by: BaRW  The door on this dishwasher opens to far. Once open the door is past level with the floor. This creates a bump when rolling the bottom try in or out. Even when open this wide it does not feel solid. Is there a stop somewhere that I'm missing. BaRW, There is a stop, but that is usually not the issue. You will need to dismantle the door assembly and check the door liner Part number: AP4057395
hinge attachment point and screws for distortion , bent , loose screws, etc. Then check the hinges and the pivot points on the tub frame for the same possible issues, Part number: AP3965273
