Compressor tries to turn on buzzes and shuts off. Not cooling when this happens. I tried it this morning and the compressor kicked on so i left it plugged in for the day. When I returned compressor was hot and every thing appeared shut down. Fridge was not cool but there was some condensation on coils on the back wall of the freezer.
Most likely the problem is a bad start relay for the compressor. If it would not help then the compressor itself has gone bad. - The start relay Part number: AP4367355
