ornestreet
#1 Posted : Tuesday, July 30, 2013 4:48:12 AM(UTC)
ornestreet
My fridge isn't working but my freezer is.
Based on other threads, I opened the back panel to check for frost. No frost, the coils look totally clean.
I turned the fridge on and the fan behind the back panel in the freezer (the evaporator fan? my terminology might be wrong) is spinning happily.
I can't see any ice blockage further up between the fan and the fridge. But maybe there is? How do I check for it? What else could be going wrong?
Is there a fan in the top part / fridge module that could be broken? I'm not hearing any sounds coming out of the fridge part.
ornestreet
#2 Posted : Tuesday, July 30, 2013 4:56:53 AM(UTC)
ornestreet
The fridge is from 2002, if that helps.
