dkummick@aol.com
#1 Posted : Friday, March 2, 2012 7:26:28 AM(UTC)
dkummick@aol.com
When dishwasher is filling with water, I get an IE error code and cycle is stopped. I've replaced the Water Inlet Valve and the Guide Assembly and still get the error code. Where do I go from here? I have good water flow and wait for the temperature to get hot before starting the machine. All hoses are good and electrical connectors are tight. What is the Item A106 on the parts diagram? It is called a Filter Assembly but there is no water connection to this part on the machine. It has a circuit board on it on the dishwasher.
:confused:
Simon / APP Team
#2 Posted : Friday, March 2, 2012 2:57:44 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Take the outer door panel off and check the wires stocked in the black insulation. That could be you answer.
The A106 item is the electrical noise filter. Has nothing to do with you problem.
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
LG dishwasher bE Bubble Error (Dishwasher Repair)
by Guest 2/13/2024 10:58:29 AM(UTC)
LG dishwasher loud clicking noise after cycle completes (Dishwasher Repair)
by Guest 10/29/2023 6:43:16 AM(UTC)
LG Dishwasher will wash but won't dry (Dishwasher Repair)
by chrisguy 8/14/2023 2:12:31 PM(UTC)
LG Dishwasher Vents too much into door (Dishwasher Repair)
by 1of10inMD 5/1/2023 9:34:04 AM(UTC)
LG Dishwasher not cleaning dishes (Dishwasher Repair)
by diyrepairdishwasher 9/30/2022 5:50:39 AM(UTC)
LG dishwasher racks (Dishwasher Repair)
by Guest 8/16/2022 3:20:01 PM(UTC)
Error Codes on lg dishwasher LDF5545st (Dishwasher Repair)
by Guest 7/25/2022 10:57:38 AM(UTC)
LG Dishwasher LDS4821ST Drain issue (Dishwasher Repair)
by Guest 6/27/2022 12:40:11 PM(UTC)
Lg dishwasher whistling (Dishwasher Repair)
by Help89 2/1/2022 3:21:08 AM(UTC)
LG Dishwasher Leaking When First Turned On (Dishwasher Repair)
by artriumph 4/22/2021 1:13:56 PM(UTC)
LG Dishwasher - LDF7932ST (Dishwasher Repair)
by Raptor_57 2/6/2021 5:28:18 AM(UTC)
LG Dishwasher Srainless Discoloration/Rainbow (Dishwasher Repair)
by Thejdpuller 1/31/2021 6:17:49 PM(UTC)
cleaning LG dishwasher filter part ADQ32598202 (Dishwasher Repair)
by phillman5 9/4/2019 12:08:33 AM(UTC)
LG dishwasher shutting down after I select wash cycle (Dishwasher Repair)
by Jon Lamoureux 11/10/2018 10:42:42 AM(UTC)
