Soap dish opens okay, soap ends up on the bottom of the washer and the dishes don"t get clean. Water fills to the proper level any Ideas?
Remove the lower spray arm and the pump cover. Remove the pump filter and the rinse arm assembly (#6 & #7 on the diagram) and clean them using white vinegar and a tooth brush. Gene.
