LS
livesteamr@msn.com
#1 Posted : Sunday, August 2, 2009 1:41:16 PM(UTC)
livesteamr@msn.com
Soap dish opens okay, soap ends up on the bottom of the washer and the dishes don"t get clean. Water fills to the proper level any Ideas?
#2 Posted : Monday, August 3, 2009 3:07:06 PM(UTC)
Remove the lower spray arm and the pump cover. Remove the pump filter and the rinse arm assembly (#6 & #7 on the diagram) and clean them using white vinegar and a tooth brush.
Savings through Textbook Rentals (General Talk)
by Guest 6/25/2024 4:12:42 AM(UTC)
Maximizing Savings through Textbook Rentals (General Talk)
by Guest 6/9/2024 10:31:43 PM(UTC)
Ice behind fan pannels in refrigerator and fan not working (Refrigerator & Freezer Repair)
by Mark7604 6/9/2024 6:43:14 AM(UTC)
Kitchenaid Oven range Superba kgsc308lss0 not heating up (Oven Repair (including Ranges and Cooktops))
by rattty 5/19/2024 6:51:16 PM(UTC)
Maytage PYE3300AYW: can't seat drum on new wheels (Dryer Repair)
by Guest 4/26/2024 3:05:06 PM(UTC)
Evaporator Coils Keep Freezing (Refrigerator & Freezer Repair)
by Guest 4/6/2024 5:31:47 AM(UTC)
Whirlpool Oven - Controls Don't Work (Oven Repair (including Ranges and Cooktops))
by Guest 3/25/2024 10:18:22 AM(UTC)
Hotpoint timer stalls in middle of opperation (Dishwasher Repair)
by Fidofax 2/15/2024 8:50:49 AM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Dishwasher fills and drains only. Does not go through the wash and rinse cycle (Dishwasher Repair)
by Guest 2/11/2024 6:26:48 AM(UTC)
GE Washer Topload model I have a GE top load washer GTW750CPL0DG. It fills and it is running but whe (Washer Repair)
by MimiReel 1/28/2024 12:03:27 PM(UTC)
Frigidaire FSG747GES0 dryer motor (P/N 131461900) growls on start (Dryer Repair)
by RJ539 1/12/2024 9:00:21 AM(UTC)
Frigidaire model # FFSC2323LSCA (Refrigerator & Freezer Repair)
by Guest 1/8/2024 11:46:06 AM(UTC)
Frigidaire ac unit FFRE08LS16 (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 11/10/2023 7:46:44 AM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
