jarrattbl
#1 Posted : Tuesday, July 21, 2009 5:08:09 PM(UTC)
jarrattbl
Have a washer that won't do anything but fill the tub. I replaced the timer thinking that was the problem but I didn't fix the problem. What would be wrong to stop it from agitating, spinning, or draining?
applianceman
#2 Posted : Tuesday, July 21, 2009 6:56:34 PM(UTC)
applianceman
The lid switch is the first thing I would check. Sometimes the little white knob (#215 on the parts breakdown) on the lid switch will fall off and the lid switch actuator on the lid cannot make the switch. If this is the case you may be able to find it in the bottom of the case and glue it back on. If this is not the case the switch itself may be bad you can check for continuity across it. GE Washer Not Running Repair Guide
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore heavy duty extra capacity washer won't work (Washer Repair)
by petens 11/9/2018 1:44:47 PM(UTC)
Washer Won't Work on Light Cycle (Washer Repair)
by lum 7/15/2014 11:30:01 AM(UTC)
Frigidaire Dishwasher won't work after power outage (Dishwasher Repair)
by kellyaj_99 1/8/2013 1:20:17 PM(UTC)
Normal Cycle Light Blinking, Dishwasher won't work (Dishwasher Repair)
by CAGAGAGC 11/30/2012 8:17:22 AM(UTC)
Whirlpool washer won't work with clothes in it (Washer Repair)
by cabellabbott 12/19/2011 4:47:23 PM(UTC)
Whilpool washer won't work with clothes in it (Washer Repair)
by cabellabbott 12/19/2011 4:46:01 PM(UTC)
Washer won't work, makes odd noise and nothing (Washer Repair)
by Blondiemom 5/28/2011 10:19:09 AM(UTC)
dishwasher won't work (Dishwasher Repair)
by rronnie 2/27/2011 12:54:08 PM(UTC)
Washer won't work on Cold/Cold (Washer Repair)
by SocialD 2/19/2011 3:23:41 PM(UTC)
Maytag topload washer won't work (Washer Repair)
by agrent12345 2/3/2011 7:30:38 PM(UTC)
Stackable washer won't work (Washer Repair)
by lon 11/30/2010 10:34:16 AM(UTC)
whirlppool washer won't work (Dryer Repair)
by hassanhameed 9/15/2010 9:19:16 AM(UTC)
Washer won't work unless dryer is on. (Washer Repair)
by dru 6/12/2010 12:41:05 PM(UTC)
Dishwasher won't work on its own anymore (Dishwasher Repair)
by Thumpette 1/26/2010 3:41:41 PM(UTC)
