My washer is working properly. At first I noticed that the clothes were very wet after being washed, and then the washer just stopped spinning. We tried changing the drain pump, and that didn't help. Next, we tried changing the control panel, and that didn't help. Finally, we changed the door lock, and the washer worked perfectly without any clothes in it. However, as soon as I put a load of laundry in it, it filled with water, turned several times to begin washing, and just stopped. Any ideas about what might be wrong?
Well, by the process of elimination I am going to suggest replacing the motor control board. That shouldn't be the problem, but you have done all of the other things.
