Have a washer that won't do anything but fill the tub. I replaced the timer thinking that was the problem but I didn't fix the problem. What would be wrong to stop it from agitating, spinning, or draining?
The lid switch is the first thing I would check. Sometimes the little white knob (#215 on the parts breakdown) on the lid switch will fall off and the lid switch actuator on the lid cannot make the switch. If this is the case you may be able to find it in the bottom of the case and glue it back on. If this is not the case the switch itself may be bad you can check for continuity across it. GE Washer Not Running Repair Guide
