scottsraptor@aol.com
#1 Posted : Monday, July 20, 2009 8:56:02 AM(UTC)
I have an oven that has started to take a really long time to heat up. Sometimes close to an hour, and sometimes never heating up to 350 at all, it only gets to about 300. I was wondering what part is broken and what I can do to fix it. Thanks for your help!
#2 Posted : Monday, July 20, 2009 12:53:52 PM(UTC)
Did the Bake element get red?
#3 Posted : Tuesday, July 21, 2009 7:24:28 AM(UTC)
no it dosent thern red
#4 Posted: : Tuesday, July 21, 2009 11:41:36 AM(UTC)
How it works on Broil?
#5 Posted : Tuesday, July 21, 2009 3:38:37 PM(UTC)
I think we got it figuerd out it works on broil. so i think the botom heat eliment dosent work so i have orderd it will see what hapens thanks for your help
#6 Posted : Friday, July 24, 2009 9:01:10 PM(UTC)
I replaced the bottom heat element and it still doesn't heat up. When the part came to me it was bent, I don't know if that could have made a difference. So, to re-cap: The broiler works, but the bottom doesn't heat up at all. I'm not sure what else could be the problem, or what I should replace. I did pull out the oven and looked at the wireing, and everything looked okay. Any other suggestions?
#7 Posted : Saturday, July 25, 2009 1:22:31 PM(UTC)
Sounds like the problem is a bad relay board (#11 on the diagram).
- The relay board Part number: AP4095668
Electric Oven Slow to Heat Up (Oven Repair (including Ranges and Cooktops))
by deere420 1/30/2017 5:34:03 AM(UTC)
oven slow to heat up (Oven Repair (including Ranges and Cooktops))
by ndobois@yahoo.com 10/29/2013 10:55:04 AM(UTC)
Modern Maid Slow to Heat Up (Oven Repair (including Ranges and Cooktops))
by postman56 1/30/2011 5:18:34 PM(UTC)
gas oven slow to heat up/achieve desired temperature (Oven Repair (including Ranges and Cooktops))
by FPF 1/1/2011 1:09:12 PM(UTC)
oven is very slow to heat up then will not hold temp. (Oven Repair (including Ranges and Cooktops))
by boblmoran123 3/8/2010 4:35:51 PM(UTC)
Oven slow to heat up but broiler works (Oven Repair (including Ranges and Cooktops))
by drcain 12/16/2007 12:03:05 PM(UTC)
Oven slow to heat up (Oven Repair (including Ranges and Cooktops))
by ladbroke 12/11/2007 8:43:12 PM(UTC)
