I have an oven that has started to take a really long time to heat up. Sometimes close to an hour, and sometimes never heating up to 350 at all, it only gets to about 300. I was wondering what part is broken and what I can do to fix it. Thanks for your help!
Did the Bake element get red?
Originally Posted by: Gene  Did the Bake element get red?
Gene. no it dosent thern red
How it works on Broil?
Originally Posted by: Gene  How it works on Broil?
Gene. I think we got it figuerd out it works on broil. so i think the botom heat eliment dosent work so i have orderd it will see what hapens thanks for your help
Gene. I replaced the bottom heat element and it still doesn't heat up. When the part came to me it was bent, I don't know if that could have made a difference. So, to re-cap: The broiler works, but the bottom doesn't heat up at all. I'm not sure what else could be the problem, or what I should replace. I did pull out the oven and looked at the wireing, and everything looked okay. Any other suggestions?
