lnahudson
#1 Posted : Thursday, January 3, 2008 5:30:48 PM(UTC)
lnahudson
My Kenmore 417.41042000 is not properly spinning.
I started going through the diagnostic test but didnt make it past step one. Once I took the belt off the motor will indeed start to spin during the cycle. No noise but (dont try this at home...) with a rag in my hand I can stop the motor. I turns freely as does the drum. I have no growling noises belt looks good, turns freely ..etc
Any suggestions?
#2 Posted : Friday, January 4, 2008 12:44:58 PM(UTC)
It does not spin at all or it spins slower then usual?
Does it tumbles normally?
lnahudson
#3 Posted : Friday, January 4, 2008 12:56:31 PM(UTC)
lnahudson
Well with the switch going through normal cycle it does not does not spin at all when it is loaded. I have to say that my symptoms seem to be intermediate after some fidgetting around I put the belt back on and set it to the spin cycle and got it to work..once. It spun up to normal speed and finished the spin cycle. But when I just have it running through the normal cycle it does not seem to have enough juice to turn the drum over. We tried several loads, and several times with it empty but it just sits throughout the cycle. I don't what I did different that time I got it to spin when setting it diretly to spin but i was not able to repeat it. Possible bad speed control board?
#4 Posted : Tuesday, January 8, 2008 10:25:07 AM(UTC)
Most likely the problem is a bad speed control board.
- The part number for the speed control board is AP3967975
Good luck.
lnahudson
#5 Posted : Tuesday, January 8, 2008 6:30:41 PM(UTC)
lnahudson
New speed control board came today. New part...same problem. I cant get the washer to spin at any point on the timer, and I have a new speed control board. Is there something else besides the motor that could be causing this now?
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
GE Washer wont spin at the high speed GHWN4250D0WW (Washer Repair)
by ssauer40 1/10/2022 4:19:44 AM(UTC)
washer wont spin (Washer Repair)
by allen9258 4/8/2018 11:08:33 PM(UTC)
Maytag Bravos Washer wont spin (Washer Repair)
by utzzy27 10/2/2016 1:15:15 PM(UTC)
washer wont spin out (Washer Repair)
by dokratt 4/16/2016 2:50:25 PM(UTC)
Maytag Neptune washer wont spin or cycle (Washer Repair)
by Tonya 44 11/17/2015 12:56:58 PM(UTC)
ge washer wont spin or agitate (Washer Repair)
by outback32 9/29/2015 9:46:08 AM(UTC)
by Denarae 8/4/2015 7:21:30 AM(UTC)
Frigidaire Washer Wont spin high speed (Washer Repair)
by jchi2210 12/17/2014 12:01:09 PM(UTC)
washer wont spin& drain (Washer Repair)
by aristeoherrera@gmail.com 12/10/2014 3:19:57 PM(UTC)
by lvest 7/26/2014 11:09:50 AM(UTC)
by Mattbri 5/30/2014 11:16:21 AM(UTC)
ge profile washer wont spin (Washer Repair)
by ron1821 3/24/2014 4:57:26 PM(UTC)
GE profile washer wont spin (Washer Repair)
by ron1821 3/19/2014 11:31:36 AM(UTC)
Maytag washer wont spin, smoking from under and smells like burnt rubber (Washer Repair)
by trytodiy 3/13/2014 6:20:43 PM(UTC)
