Letty Jo
#1 Posted : Monday, February 6, 2012 12:53:05 PM(UTC)
Letty Jo
oUR MAYTAG WASHER IS LEAKING FROM UNDERNEATH IT SEEMS LIKE IT
IS FROM THE RIGHT FRONT. aNY IDEAS. tHANKS
#2 Posted : Monday, February 6, 2012 4:18:50 PM(UTC)
Letty,
You will need to take the front panel off in order to determine the leak.
Remove the two screws under the edge at the bottom of the front panel. Swing the front panel out from the bottom to disengage spring fasteners from the top cover.
Run the washer and post the results.
Here are the breakdown diagrams and Replacement parts for Maytag LAT2200AAE WASHER-TOP LOADING | AppliancePartsPros.com
Infusor washing machine leaks (Washer Repair)
by Clifton Hartoon 6/19/2015 8:22:15 AM(UTC)
Washing machine leaks water from rear air vent (Washer Repair)
by Lorri 3/13/2012 12:17:37 PM(UTC)
My washing machine leaks for every load (Washer Repair)
by vballplayer30 10/18/2011 5:02:52 PM(UTC)
Washing machine leaks above Hose(tub to pump) (Washer Repair)
by rbauerpt@cox.net 5/3/2010 8:30:00 PM(UTC)
washing machine leaks during drain cycle (Washer Repair)
by atlonnett 3/16/2010 8:06:58 AM(UTC)
Washing machine leaks (Washer Repair)
by willjsch 9/1/2009 11:22:47 AM(UTC)
by Ravenwr 3/2/2009 3:18:46 PM(UTC)
My GE washing machine leaks durring spin cycle. (Washer Repair)
by Ethan Blue 2/23/2009 8:35:20 AM(UTC)
Washing Machine Leaks From Front Tab Seal (Washer Repair)
by konekwek 12/8/2008 12:15:17 PM(UTC)
GE Washing machine leaks (Dishwasher Repair)
by Wadester 10/15/2008 10:42:36 AM(UTC)
