Ravenwr
#1 Posted : Monday, March 2, 2009 3:18:46 PM(UTC)
Ravenwr
My washing machine drips water into the tub after the final spin cycle. The drip is similar to a faucet drip. What could it be?:mad:
TechnicianBrian
#2 Posted : Monday, March 2, 2009 4:42:22 PM(UTC)
TechnicianBrian
If water continues to drip after use, then the inlet valve is likely not sealing shut and may need to be replaced. Post a model number and we can guide you in the right direction.
Guest (4)
Infusor washing machine leaks (Washer Repair)
by Clifton Hartoon 6/19/2015 8:22:15 AM(UTC)
Washing machine leaks water from rear air vent (Washer Repair)
by Lorri 3/13/2012 12:17:37 PM(UTC)
by Letty Jo 2/6/2012 12:53:05 PM(UTC)
My washing machine leaks for every load (Washer Repair)
by vballplayer30 10/18/2011 5:02:52 PM(UTC)
Washing machine leaks above Hose(tub to pump) (Washer Repair)
by rbauerpt@cox.net 5/3/2010 8:30:00 PM(UTC)
washing machine leaks during drain cycle (Washer Repair)
by atlonnett 3/16/2010 8:06:58 AM(UTC)
Washing machine leaks (Washer Repair)
by willjsch 9/1/2009 11:22:47 AM(UTC)
My GE washing machine leaks durring spin cycle. (Washer Repair)
by Ethan Blue 2/23/2009 8:35:20 AM(UTC)
Washing Machine Leaks From Front Tab Seal (Washer Repair)
by konekwek 12/8/2008 12:15:17 PM(UTC)
GE Washing machine leaks (Dishwasher Repair)
by Wadester 10/15/2008 10:42:36 AM(UTC)
