Ethan Blue
#1 Posted : Monday, February 23, 2009 8:35:20 AM(UTC)
Ethan Blue
My friends GE washing machine leaks durring the spin cycle. It leaks out the front right and front left, becayse the base of the unit has a bracket going across to keep if from leaking out the front. The hoses in the back are fine and I am have trouble finding where the leak is coming from... any thoughts?
#2 Posted : Monday, February 23, 2009 6:29:29 PM(UTC)
Ethan,
Remove the front panel and run the washer to see where it is leaking from. Post the results.
Here are the break down diagrams and the parts list for the GE washer Model WPSR3120W2WW
Guest (4)
