ralph werner
#1 Posted : Monday, January 30, 2012 4:44:59 PM(UTC)
ralph werner
A friend was trying to get crushed ice and nothing was coming out . He kept grinding away until the motor stopped. My thought was that the motor had burned out.
The motor has 4 wires - BR/WH, RD/WH, GY,BU on terminals 1,2 5,7.
I didn't get voltage readings with 1,2 connected and the dispenser lever depressed (the light went on and the freezer door switch was taped). On the motor there were 75 ohms between 1-2 and 14 ohms between 5-7.
My questions are :Is the micro switch likely to go in this situation? How easy is it to replace the switch? Can I do anything more to test the motor (I have no way to supply DC current to 1-2).
Thanks.
ApplianceJunk
#2 Posted : Monday, January 30, 2012 4:57:08 PM(UTC)
ApplianceJunk
Please check the model number. I can't find a CG3SHEXN
Is this the style with the ice storage bin in the freezer door? If so here is the service manual. Maybe you will find it helpful.
4322658A R-92 Whirlpool and KitchenAid Indoor Ice System - Ice Maker Service Repair Manual
Testing an ice dispenser motor- Kitchenaid/Whirlpool (Refrigerator & Freezer Repair)
by viabill 5/8/2019 5:59:09 PM(UTC)
burning up Whirlpool ice dispenser motors (Refrigerator & Freezer Repair)
by dicktrickle88 6/3/2015 12:05:20 PM(UTC)
Ice dispenser motor wire schematic (Refrigerator & Freezer Repair)
by flymom 7/27/2014 11:14:15 AM(UTC)
Can' t unscrew auger from ice dispenser motor shaft (Refrigerator & Freezer Repair)
by Mtwoodson 8/6/2013 8:52:22 PM(UTC)
ice dispenser motor replaced and still doesnt work (Refrigerator & Freezer Repair)
by bryan9097 7/18/2012 9:30:50 AM(UTC)
ice dispenser motor won't turn off (Refrigerator & Freezer Repair)
by Warren R 5/16/2012 10:08:55 AM(UTC)
New Ice dispenser Motor (Refrigerator & Freezer Repair)
by jurgyman 2/16/2012 5:46:53 AM(UTC)
Ice dispenser motor replacement (in door) (Refrigerator & Freezer Repair)
by lhawthorne3 1/19/2012 3:40:23 PM(UTC)
How To Change Ice Dispenser Motor (Refrigerator & Freezer Repair)
by ratchet52 11/29/2011 2:30:52 PM(UTC)
ice dispenser motor turning wrong way (Refrigerator & Freezer Repair)
by rogerstreetman 10/12/2011 10:14:42 AM(UTC)
Ice Dispenser Motor will not turn (Refrigerator & Freezer Repair)
by tcounts 9/12/2011 8:37:02 AM(UTC)
by ETGolfer 8/29/2011 9:49:25 AM(UTC)
Ice dispenser motor - no sound (Refrigerator & Freezer Repair)
by dkeeb 12/15/2010 3:12:25 PM(UTC)
Ice dispenser motor keeps freezing up (Refrigerator & Freezer Repair)
by TJLight 8/23/2010 9:57:15 AM(UTC)
how to replace ice dispenser motor (Refrigerator & Freezer Repair)
by 1954bigd 1/12/2009 2:42:33 PM(UTC)
