looz98
#1 Posted : Friday, July 10, 2009 2:04:13 PM(UTC)
looz98
my washer isn't agitating nor is it spining.....what could this problem be and is it worth the fix?
magician59
#2 Posted : Friday, July 10, 2009 2:34:19 PM(UTC)
magician59
Move it out from the wall far enough to tip it back. Tip it back far enough that it will balance there and not tend to fall forward. Get down on the floor and remove the belt, then try to manually spin the pump pulley and the transmission pulley (in both directions). If you can't move one or the other, that is the component that needs to be replaced. If they both freely rotate, select a spin cycle and start it to see if the motor will run without the belt. If it won't run, the problem is in the motor circuit.
looz98
#3 Posted : Friday, July 10, 2009 3:00:44 PM(UTC)
looz98
did what you said ...now its agitating and spining right now as i'm running it thru a cycle....? for you when that happened the water drained out so the pump was working and im presuming that the motor was working.... what could have caused that ?
thanks again for info!!
magician59
#4 Posted : Friday, July 10, 2009 3:41:43 PM(UTC)
magician59
It sounds like you may have had an obstruction in the pump thqt was dislodged, or maybe an intermittent problem with the lid switch.
looz98
#5 Posted : Saturday, July 11, 2009 4:44:18 AM(UTC)
looz98
thanks again...i'll keep an eye on this ....
Whirlpool WTW4815EW1 Washer Won't Spin or Agitate (Washer Repair)
by dann1551 4/7/2021 8:42:00 AM(UTC)
won't spin or agitate (Washer Repair)
by KeithMinnick 4/2/2018 1:35:46 PM(UTC)
Kenmore model 110 Won't spin or agitate (Washer Repair)
by gibstuff 6/6/2017 10:27:57 PM(UTC)
Washer won't spin or agitate (Washer Repair)
by dhughes 4/1/2017 10:17:04 AM(UTC)
GE washer won't spin or agitate. (Washer Repair)
by Eric9999 12/21/2015 10:19:03 AM(UTC)
GE Washer won't spin or agitate (Washer Repair)
by whovian2015 9/30/2015 2:56:35 PM(UTC)
GE Profile 175D2750G151 Won't spin or agitate (Washer Repair)
by Mitchina 6/28/2015 6:04:43 AM(UTC)
Washer Won't Spin or Agitate, but Drains Properly (Washer Repair)
by Levistahl 10/16/2014 10:21:32 AM(UTC)
washer won't spin or agitate (Washer Repair)
by tibbs1212 9/7/2014 6:01:49 PM(UTC)
GE Hydrowave washer won't spin or agitate (Washer Repair)
by lilajfischer 8/7/2014 3:20:38 PM(UTC)
Hotpoint washer won't spin or agitate (Washer Repair)
by cmccms 1/28/2014 10:42:17 AM(UTC)
Kenmore washer won't spin or agitate (Washer Repair)
by jwes 1/23/2014 6:22:22 PM(UTC)
Whirlpool Washer won't Spin or Agitate (Washer Repair)
by Jimmimech 1/12/2014 6:57:46 PM(UTC)
by MamaFixedIt 7/19/2013 7:47:18 AM(UTC)
by mmcgarcia 6/15/2013 12:47:09 PM(UTC)
