Hello , I have a thermador double oven model #sc302t. The bottom oven doesnt work. The touch panel works for the upper oven but not the lower ( But off button ) is the only one that beeps. Would the touch pannel be bad or maybe the lower relay? or something else?
I am having the same trouble. My ovens are about 11 years old and the touch panel button that shows upper/lower will not work and neither will the lower oven buttons (no sound when touched). I got a $1700 quote to replace a bunch of parts that "might" be the problem. I'd rather buy a new oven than waste $1700 but checked this forum to see if there were some easier things to try on our own.
