cnlmerrell
#1 Posted : Tuesday, January 10, 2012 7:42:51 PM(UTC)
cnlmerrell
Hello , I have a thermador double oven model #sc302t. The bottom oven doesnt work. The touch panel works for the upper oven but not the lower ( But off button ) is the only one that beeps. Would the touch pannel be bad or maybe the lower relay? or something else?
JFulkerson
#2 Posted : Sunday, March 9, 2014 1:25:16 PM(UTC)
JFulkerson
I am having the same trouble. My ovens are about 11 years old and the touch panel button that shows upper/lower will not work and neither will the lower oven buttons (no sound when touched). I got a $1700 quote to replace a bunch of parts that "might" be the problem. I'd rather buy a new oven than waste $1700 but checked this forum to see if there were some easier things to try on our own.
Thermador double oven from '99 troubleshoot (Oven Repair (including Ranges and Cooktops))
by mike_balt 5/6/2024 4:16:42 PM(UTC)
thermador double oven no power to lower (Oven Repair (including Ranges and Cooktops))
by tomstir 3/18/2021 1:36:53 PM(UTC)
Thermador double oven no display (Oven Repair (including Ranges and Cooktops))
by daiwa0411 10/8/2020 7:12:03 AM(UTC)
Thermador Double Oven - Top Oven turns off F5 and F7 (Oven Repair (including Ranges and Cooktops))
by MattLester 2/9/2015 12:11:39 PM(UTC)
Thermador double oven F33 errors (Oven Repair (including Ranges and Cooktops))
by xyoptus 1/1/2015 11:26:32 PM(UTC)
Thermador Double Oven not working properly (Oven Repair (including Ranges and Cooktops))
by rxrep 12/28/2014 10:32:11 AM(UTC)
Thermador double oven control panel (Oven Repair (including Ranges and Cooktops))
by Malcolm Phillips 1/7/2013 4:40:27 PM(UTC)
Thermador Double Oven Self Clean (Oven Repair (including Ranges and Cooktops))
by canalking 1/28/2012 6:08:01 AM(UTC)
Thermador Double Oven (Oven Repair (including Ranges and Cooktops))
by manoog 1/8/2012 5:27:16 PM(UTC)
thermador double oven does not heat (Oven Repair (including Ranges and Cooktops))
by sport99 8/15/2010 6:07:27 PM(UTC)
60's Thermador double oven - low voltage (Oven Repair (including Ranges and Cooktops))
by doublebubble 4/4/2010 1:23:00 PM(UTC)
Thermador Double oven (Oven Repair (including Ranges and Cooktops))
by rmahre 6/9/2009 10:41:09 AM(UTC)
thermador double oven/microwave (Oven Repair (including Ranges and Cooktops))
by bocasue8 3/20/2009 2:39:22 PM(UTC)
Thermador Double Oven No self clean top (Oven Repair (including Ranges and Cooktops))
by JWLloyd 3/13/2009 8:16:45 AM(UTC)
by KMunday 3/6/2009 11:26:36 AM(UTC)
