When I get water from the water dispenser it continues to drip after I have finished dispensing water. This happens even if I "lock" the water dispenser off. Any suggestions?
This can be caused by air in the line, which can be caused by unhooking the line or changing the filter (if you have one). If you have recently done anything to cause air to be in the line simply run the water until all the air is out and it will be fixed. If this is not your problem I would say replace the water valve. Refrigerator repair guide
