david465
#1 Posted : Wednesday, March 10, 2010 5:27:17 PM(UTC)
david465
I had a leaky water dispenser that ended up stopping working so I thought no brainer and replaced the water inlet valve. Still had leak. Had a saddle valve so I thought I might have low water pressure so I installed a shutoff. Water dispenser is still dripping. Thought maybe my water filter could be plugged so I replaced it and water dispenser still drips. I can't find any leaks anywhere. What should I do next? Thanks.
#2 Posted : Thursday, March 11, 2010 2:34:44 AM(UTC)
If the water pressure at the dispenser is low, you might have a partially frozen plastic line in the door, this is the only thing that makes sense. Try warming it with a hair dryer.
david465
#3 Posted : Thursday, March 11, 2010 12:41:36 PM(UTC)
david465
I had the fridge unplugged for a full day defrosting it. So I really doubt that is the problem. Also, there is good flow coming out of the water dispenser. Any other ideas? Thanks.
#4 Posted : Thursday, March 11, 2010 2:58:24 PM(UTC)
The drip may be from frozen insulation. If so, it will still drip when the water is turned off.
gmbdinc
#5 Posted : Thursday, March 11, 2010 3:12:34 PM(UTC)
gmbdinc
Check to see if the door assembly is closed completely, I don't know how much of a drip you have but the condensation on an open/stuck door can be substantial. If that is the problem, check out the ice door kit AP4009082 especially the solonoid.
